It is currently Sat Jul 18, 2026 7:45 pm
PostPosted: Mon Jul 26, 2010 6:51 am
No scales nearby.
How do I weigh my race car?
Id like to use a torque wrench to weigh all 4 corners.
Any ideas?
PostPosted: Mon Jul 26, 2010 10:22 am
I have heard of using bathroom scales with fulcrums to decrease the load on the scale by a known amount. You would have to use a known weight to calibrate it well. I would think a torque wrench might not be as accurate.
Bring it down to my garage and we can corner weight it...
PostPosted: Mon Jul 26, 2010 1:26 pm
so.......if the anticipated weight per corner was 700lbs......
I use an eightfoot 4x4 with the fulcrum at 1 ft from the end resting on the bathroom scale. I push 100lbs to lift the corner.......
Are you allowed open pipes and cut tires on your street?
 Post subject: Its easier than that!
PostPosted: Mon Jul 26, 2010 2:01 pm
so I took my Big Bar......1" drill rod 50" long.
......tossed a block under the car and started prying.
Once I had the car lifted with the bar I measured from axle centre to fulcrum (6") and from fulcrum to the end where my knee was exerting all my 160lbs (42")
so if 6" = 1 then 42= 7 ....so 7x 160lbs = 1120lbs on the front
The same procedure got me about 1250lbs on the rear
That means about 2370 for the whole car. A lil less than I had figgerd....
I used the bathroom scale to weigh myself ..........Im so dirty I weigh 5 lbs more than I do after my bath!
PostPosted: Mon Jul 26, 2010 2:14 pm
Sounds like a good first pass. Interested to see what happens if you do it on a different day with fresh setup.
Open pipes, yes, but limited. Cut tires should be fine, but I'll have to ask the neighbors...
Goin' back to Hagerstown this weekend - will miss ya there!
PostPosted: Mon Jul 26, 2010 4:08 pm
Bring it down to my shop. Patrick has a set of corner scales we can put it on.
Open pipes, cut tires, mud dragger..........they'd prolly let you be mayor for the day. :lol:
PostPosted: Mon Jul 26, 2010 5:28 pm
///////////same thing gets me "A$$h0le of the day" here///////////////
PostPosted: Mon Jul 26, 2010 5:31 pm
Take it apart and weigh the pieces................
:D
PostPosted: Tue Jul 27, 2010 5:51 am
Ooo, Ed I like that... I've done it before too, for most of the parts.
PostPosted: Tue Jul 27, 2010 1:46 pm
They do not have dumps in Canada?
Raymond Flynn
Registered Six Offender!!!!
PostPosted: Tue Jul 27, 2010 2:02 pm
The closest dump that weighs stuff is 2.5 hours and a ferry ride away.
There are log dumps that weigh full logging trucks 45 mins and a ferry ride away.....but they weigh 40,000 to 100,000lbs.
Weighing all the parts doesn t help with front/rear distribution......
