It is currently Wed Jun 17, 2026 6:02 am
 Post subject: Duel carb w/ turbo ?
PostPosted: Thu Jul 29, 2010 6:13 pm
Using carter 1 bbl carbs
split manafold (one carb feeds 3 pistons)
Think adding a small turbo would be do able ...with this set up?
just throwing it out there...
Its so nice out side, I think I'll go lay under my car..
PostPosted: Thu Jul 29, 2010 9:19 pm
Car Model: 1968 A108 225/3 on the tree
what r u using for exhaust header? split headers mite let u set up dual turbos?
PostPosted: Thu Jul 29, 2010 9:26 pm
Sure, why not? You'll have to seal up the accelerator pump somehow or box the carbs. Also, many BBS carbs I've seen don't have tops that seal very well so that will be an issue. I hope you can modify the power enrichment circuit to get enough fuel flow.
PostPosted: Fri Jul 30, 2010 4:48 pm
Why not go with two super six carbs? You could modify an offy 2-1 barrel intake or make a plate to adapt them to said manifold. Or better yet, instead of four venturi's (which makes no sense to me when used on a six cylinder) you could do three one barrels, if you can make your own manifold that is. Back when tossing the idea around of having three holley one-barrels on a NA setup, I drew up a really good picture you can find mid-way down the third page here:http://www.slantsix.org/forum/viewtopic ... 4&start=30
Hope I've provided sufficent food for thought.
PostPosted: Fri Jul 30, 2010 8:44 pm
link doesn't work for me. . . .
PostPosted: Sun Aug 01, 2010 7:07 pm
:? it works for me... has it worked for anyone else.
PostPosted: Mon Aug 02, 2010 7:49 am
2day it worked fine. must be my computer.
 Post subject: -
PostPosted: Tue Aug 03, 2010 6:43 am
Keep it simple,One turbo and carb will be hard enough to tune and get worked out.
Users browsing this forum: Bing [Bot] and 6 guests
