It is currently Fri Jun 19, 2026 11:53 pm
 Post subject: carb leaks!
PostPosted: Mon Aug 02, 2010 11:40 am
i have a carter reman 2 barrel carb on my slant 6. my major vacuum leak is on the shaft that holds the discs ....how do i seal these?? .theres no rubber gasket or bushing???
thanks jimbo
dodge b150 4x4 225 supersix,8 inch lift26605_1315915292058_1055981099_30764636_7102626_n
PostPosted: Wed Aug 04, 2010 8:45 am
Thats a very common leakage area on the BBD's. You'll have to take it down to a carb shop and have the throttle shaft rebushed. It'll probably run you around $60 or $80.
If you just bought the carb I would just go get my money back and find a NOS one online.
PostPosted: Wed Aug 04, 2010 11:29 am
thanks man. i fixed the problem by adding some rubber o rings but i'm having a problem .only one barrel is working it seems like the other isn't getting enough suction . i've already changed everthing possible that controls any outside vacuum leak from the carb. what would be causing only 1 barrel to work at idle ?????
thanks jim
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 2 guests
