It is currently Wed Jul 15, 2026 1:46 pm
PostPosted: Sat Sep 07, 2002 8:49 am
Hi Gang,
I finally got a hazard light harness for my 1966 Dart GT. 2 quick questions...
1) When I run the lead to the fuse box, which amp fuse do I connect it to?
2) Obviously, the switch assembly attaches to the lower lip of the dash. I will have to drill a hole for the switch. To which side of the steering column is the switch assembly typically found (left or right)?
Thanks,
Tom
kimpelt@pdx.edu
Users browsing this forum: Amazon [Bot] and 1 guest
