| Hazard Light Harness Install Qs. https://slantsix.org/forum/viewtopic.php?t=4134 |
| Author: | Spazus [ Sat Sep 07, 2002 8:49 am ] |
| Post subject: | Hazard Light Harness Install Qs. |
Hi Gang, I finally got a hazard light harness for my 1966 Dart GT. 2 quick questions... 1) When I run the lead to the fuse box, which amp fuse do I connect it to? 2) Obviously, the switch assembly attaches to the lower lip of the dash. I will have to drill a hole for the switch. To which side of the steering column is the switch assembly typically found (left or right)? Thanks, Tom kimpelt@pdx.edu |
