It is currently Sat Jun 20, 2026 7:54 pm
PostPosted: Sat Aug 14, 2010 3:36 pm
Anyone know where to get a quality performance cam for the early slant 6? Nothing too big, but better than stock. Thanks
SOLD! Went to New Zealand. '64 Valiant Signet 200, 2-dr hardtop. 225/4-speed/Pistol Grip, Offy 2-1bbl, Clifford headers.
Minimum government means maximum LIBERTY!
PostPosted: Sat Aug 14, 2010 4:18 pm
I do believe there still is a group buy going with Erson
http://www.slantsix.org/forum/viewtopic.php?t=21400
Some special cams have beend developed, so tell us what you're looking for so you can be pointed in the right direction.
PostPosted: Sun Aug 15, 2010 12:02 pm
I recently swapped the auto out for a 4-speed. My engine was rebuilt "stock", but I've added a set of Clifford shorty headers and the Offy 2-1bbl intake. I'm just looking for a cam that would give it more low end and maybe a 'lumpy" sound. No racing in mind, just street "coolness".
 Post subject: Lol...
PostPosted: Sun Aug 15, 2010 1:10 pm
Well you can always tighten the lash .001 or .002 on a stocker cam and it'll get lumpy...
The ERson 270 cam would retain good torque and has a little lump of you ask for the grind to be 108LSA...problem here is, once you go to more cam, you have to increase compression to make up for the extra bleed off the bigger cam has.
If you are looking for more cam without having to do too much else the small erson cam/the MP "244" cam grind is best (and actually works better if you upped the compression to 9:1).
PostPosted: Mon Aug 16, 2010 7:34 am
Im a Big Erson fan as well. But I would choose one of the RDP grinds that Doc did. I think there is a small modified RVcam that is RDP.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
