It is currently Mon Oct 12, 2026 2:31 am
 Post subject: thermostat bolt is out!
PostPosted: Mon Aug 16, 2010 2:54 am
thanks Sam , Vdart and Pierre.......used all 3 tips to get bolt out. 5 days of PB blaster, impact driver and heated up engine did the trick. Turns out bottom bolt was completely covered with red loctite.......I took out top bolt and tapped housing back and forth sideways.....a little more pb and shazzam.....out comes the bolt! Brings to mind ......If it was easy, it would not be MOPAR!
thanks everyone!
PostPosted: Wed Aug 18, 2010 7:44 pm
You are welcome. Glad to be of assistance.
Sam
