It is currently Sat May 16, 2026 11:25 pm
PostPosted: Tue Aug 24, 2010 6:39 am
Is it worth getting coil over shocks while still have torsion bars?
Was thinking of just keeping Qa1 shocks, the torsion bars and a sway bar front and rear. however I have the option of swapping the shocks for coil overs. Is it worth it?
Car is a fun street driver hopefully around 250Hp :).
thanks.
PostPosted: Tue Aug 24, 2010 8:11 am
Why do you want two springs on each front corner?
PostPosted: Tue Aug 24, 2010 5:50 pm
Friend of mine offered me a set of new front shocks, with the coil over. They were quite cheap and good brand/quality.
Wasn't sure if it would make a difference though...
PostPosted: Tue Aug 24, 2010 5:58 pm
Unless I were building a drag car and trying to eliminate every ounce of weight I could, I wouldn't bother with coil overs.
To use coil overs properly you really need to get rid of the t-bars, do some work on the lower A-arms so they don't separate from the bushings, and reinforce the top shock mount. :shock:
