| coil over shocks and torsion bars? https://slantsix.org/forum/viewtopic.php?t=41595 |
| Author: | Brussell [ Tue Aug 24, 2010 6:39 am ] |
| Post subject: | coil over shocks and torsion bars? |
Is it worth getting coil over shocks while still have torsion bars? Was thinking of just keeping Qa1 shocks, the torsion bars and a sway bar front and rear. however I have the option of swapping the shocks for coil overs. Is it worth it? Car is a fun street driver hopefully around 250Hp thanks. |
| Author: | Joshie225 [ Tue Aug 24, 2010 8:11 am ] |
Why do you want two springs on each front corner? |
| Author: | Brussell [ Tue Aug 24, 2010 5:50 pm ] |
Friend of mine offered me a set of new front shocks, with the coil over. They were quite cheap and good brand/quality. Wasn't sure if it would make a difference though... |
| Author: | slantzilla [ Tue Aug 24, 2010 5:58 pm ] |
Unless I were building a drag car and trying to eliminate every ounce of weight I could, I wouldn't bother with coil overs. To use coil overs properly you really need to get rid of the t-bars, do some work on the lower A-arms so they don't separate from the bushings, and reinforce the top shock mount. |
