It is currently Mon Nov 16, 2026 4:18 pm
 Post subject: Cooling.
PostPosted: Wed Sep 01, 2010 3:19 am
Hi I wasn't sure where to put this.
I want to get a thermo fan setup for my 1967 VC valiant.
Anyone done this kind of thing before?
What I don't understand is this:
Is the fan just always going to be on?
Or do you some how install a temperature gauge into the radiator etc so the fan knows when to turn on.
Also is this fan better or worse than the fan that is with the engine?
PostPosted: Wed Sep 01, 2010 4:03 am
Hello,
As you are in Oz,I would suggest that you have a look on the local Mopar Market board.There are more VC's in Oz than the US.:lol:
I have'nt checked all the threads,but there are 19 pages of stuff on thermo fans,and there is bound to be mention of a VC somewhere in there.
I seem to recall reading somewhere that space to fit a thermo to a VC is a problem.
On a standard installation there is a thermostat switch that brings the fan on at whatever temperature you set it for.
Happy hunting.
regards,Rod :D
PostPosted: Wed Sep 01, 2010 6:58 pm
Brussell,
Click on the red link below my name. When the picture comes up, double click on it for full screen slide show mode. In the pics you will see a GM temp sensor in my radiator. This unit turns the fan on and off. Look under the Engine FAQ for the Electrical FAQ-More Ignition information then go to Ted's Simplified Electric Fan wiring schematic info
I have been running this setup for several years now and found it to be very reliable. The only up grade I have done is loose the fuse......it melted on day about 3 years ago. I had just washed the engine compartment and it got wet. Install a 20 amp circuit breaker instead. No fuses to blow and it works great! :D
It helps in many ways providing better mileage, no heat soak if you leave it armed after shut off, no vapor locking on hot days or any hard starts. I also added a heat deflector under the carb which also helps. Hot starts after 30 minutes are explosive. No more cranking...... :D :D :D
