It is currently Tue Oct 13, 2026 6:46 pm
 Post subject: Oil pump ?'s
PostPosted: Thu Sep 09, 2010 6:27 pm
I have a Melling oil pump coming for my daily driver 1977 Aspen. Should I use the old gear off my old oil pump or should I roll the dice and just install it? I searched this subject and couldn't find an definite answer. If so besides Doc's tie rod puller how do I go about removing new gear off of pump? will a gear puller work? How about bearing knifes and a hydraulic press? I need to check the interference fit,right? Do I tack weld old one on shaft?
Thanks Mike
Thanks Mike
PostPosted: Thu Sep 09, 2010 6:37 pm
6 Pack Dart
Do Not use the new gear, you might use the old gear ?
You don't need to spot weld it should fit real snug.
Richard
PostPosted: Fri Sep 10, 2010 6:39 am
Mike a press and some bar stock will take it off. I have a jig I made and have pulled about 50 now.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: 2 types...
PostPosted: Fri Sep 10, 2010 8:17 pm
I've now encountered two types of gears on the new melling pumps...
You'll have to pull the new gear and determine if the gear and shaft are keyed or not...to see if the old/OEM gear will properly fit...
Users browsing this forum: No registered users and 16 guests
