It is currently Mon May 11, 2026 11:02 am
PostPosted: Sat Sep 25, 2010 12:30 pm
Hi there,
I need the specs for the shim spacing to the rocker arms on the shaft. 1983 dodge d150, 225 slant 6, hydraulic lifters.
Should I replace the push rods?
liftaton landscapes-edible landscaping solutions
83 d150 /6
76 w200 PW 400
PostPosted: Sat Sep 25, 2010 2:41 pm
Why do you think you need to replace pushrods?
PostPosted: Sat Sep 25, 2010 5:32 pm
just as a matter of coarse. They are all straight but im in there anywayse and it would be easy. Also with the clatter from the shims, the rocker arms dont line up totally straight with the push rod. There could be stress damage to the rod.
Does anyone know where I can get a complete rocker arm assembly?
83 d150 /6
76 w200 PW 400
Users browsing this forum: Ahrefs [Bot] and 7 guests
