| idle drops when shifting from park to dirve/reverse https://slantsix.org/forum/viewtopic.php?t=42113 |
| Author: | eppy25 [ Fri Oct 01, 2010 12:17 pm ] |
| Post subject: | idle drops when shifting from park to dirve/reverse |
Hey guys. Just wanna ask a quick question. Whenever i shift from park to drive or park to reverse; the idle drops by about 4-500 rpms. Im not sure if this is normal so any advice would help. Is there a way to stop this or is this just how these old cars run??? 1965 Dodge Dart 225 slant six |
| Author: | Reed [ Fri Oct 01, 2010 12:27 pm ] |
Putting a load on the engine, such as putting it in gear or turning on the a/c, will drop the engine RPM. 400-500 RPM seems excessive though, since your RPM in neutral should be between 750-800 RPM. |
| Author: | shadetree [ Fri Oct 01, 2010 12:29 pm ] |
| Post subject: | idle drop |
If your idle is set at 800-900 rpm in park afew hundred rpm drop is normal as the engine loads up. If the car stalls before you give it gas. Not correct idle speed. If your idle speed is as above. Go thru tuneup and maybe carb also verifiy that vaccum advance is working. lol shadetree |
