It is currently Sun Nov 15, 2026 6:35 am
PostPosted: Mon Oct 04, 2010 5:40 pm
I have look and look but can't find.
How do I check a electronic control module to see if it is good or not?
Thanks for any help you have.
flipfloppop
 Post subject: Need a special tool...
PostPosted: Mon Oct 04, 2010 8:36 pm
There used to be an old Mopar EI checking tool (basically plug it in and see if the lights light up for a good EI).
Not sure if anybody ever ended up with one of those boxes...it's kind of a limited use item to have around the garage.
PostPosted: Tue Oct 05, 2010 4:28 am
I just toss it into a bucket of water. If it sinks, I flip a coin, heads install a unit that I know works, tails I install a unit I know works, and than discard the wet one.
Just kidding, I don’t really use water…
One thing you can check is that the unit has a good ground, necessary for proper operation.
The spare unit is your test device…
PostPosted: Tue Oct 05, 2010 4:32 pm
So here is another question on a related subject (if I may but in ). Should I be getting shocked (feeling electrical current) from my ECU when my fingers are touching both the center metal "button like device" and the heat sink? I say no but then again, there are a lot of other people here that are more knowledgeable on this subject than me. :)
'68signet
"Living analog in the digital age."
PostPosted: Tue Oct 05, 2010 4:51 pm
Short answer is yes-Just like the one you get across the points and for the same reason (has to do with collapsing magnetic fields/lines of force that make the big spark)
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Wed Oct 06, 2010 2:01 pm
Thanks for the help.
I forgot to put a jumper wire on the ballist resistor .
I got it running for now.
Thanks,
Roger
flipfloppop
