Vacuum Valve on Air Breather
https://slantsix.org/forum/viewtopic.php?t=42166
Page 1 of 1
Author:  Murch [ Wed Oct 06, 2010 9:27 am ]
Post subject:  Vacuum Valve on Air Breather
I need what I believe is called a Vacuum Valve. It is the plastic piece, about 3/4" in diameter, that operates the air breather, hot air door.
The part number I have come up with is #4201385, but was told it is no longer available from Chrysler.
Any ideas on where I can get one?
BTW, it's for my 87 B150 225
Thanks in advance
Author:  slantfin [ Wed Oct 06, 2010 10:24 am ]
Post subject:  google says
Try Rock, don't forget the discount code in the Slanted Network section.
Author:  Murch [ Wed Oct 06, 2010 11:15 am ]
Thanks.
Question: How do I find the slant six discount and code you were referring to?
Author:  slantfin [ Wed Oct 06, 2010 1:17 pm ]
Scroll down to the bottom of this page. Click where it says "jump to: Select a forum". A drop-down menu should drop down. Click on "Slanted Network", and hit "go", if necessary. Click on the third post down, "Rock Auto discount code." Enter a current code into the "how did you hear about us?" box on the Rock Auto shopping cart, and you're good to go! 8)
Author:  Murch [ Wed Oct 06, 2010 1:49 pm ]
Got it, thanks for your help.
