It is currently Mon Nov 16, 2026 3:52 am
PostPosted: Mon Nov 15, 2010 9:55 pm
Car Model: 67 Valiant
hey hey,
I was cruising around today in the 67 valiant and the right turn signal just stays on solid now.
Left one works fine, i've also never had this happen before.
Is there a simple part thats needs maintenance?
PostPosted: Mon Nov 15, 2010 10:23 pm
One of the right side bulbs (or filaments) has failed.
PostPosted: Mon Nov 15, 2010 10:52 pm
Or lost a ground, or has a corroded connection. I recall when taking the grill apart I forgot the spade ground connector wire and it did funky things to the flashing.
PostPosted: Tue Nov 16, 2010 3:59 am
Sounds like you ran out of "blinker fluid". :lol:
http://kalecoauto.com/index.php?main_pa ... 72e53c0e3b
Scroll down to the 5th item.
PostPosted: Tue Nov 16, 2010 2:45 pm
i know the back bulb works, but if the front bulb goes out the right side stops blinking?
I'll go look at the front one in a second.
PostPosted: Wed Nov 24, 2010 4:09 pm
HOLY COW... Now I know where to find these things!!! lol This site is awesome!
1965 D100 225 slant 6, NP435 Utiline.
PostPosted: Sat Nov 27, 2010 8:10 pm
hhhmm.
I simply removed the bulb and cleaned the contacts off witha paper towel and now it works well.
get some
PostPosted: Sun Nov 28, 2010 1:15 pm
Brothercactus,
You may want to check & clean your kilowatt drains (grounds) for each of the exterior light sockets, and apply a bit of dielectric grease to the sockets that are exposed to moisture, or have previously corroded. Reducing as much resistance as possible in lighting circuits will promote brighter burning bulbs.
PostPosted: Mon Nov 29, 2010 11:18 am
i agree and will.
The car was re-painted in the like 94 and the light cover was still painted on in 2010!
The connection did look pretty corroded. and the lights appear mcuh brighter now.
This leads me to the next problem i'm having and i'll make a new thread to post it in.
