It is currently Sun Nov 22, 2026 6:07 pm
PostPosted: Mon Oct 11, 2010 8:22 pm
does anyone know where to get some good high performance headgaskets. i thought i saw a post somewhere about differant thickness copper one somewhere?
PostPosted: Mon Oct 11, 2010 8:53 pm
If you really feel the need for copper: http://slantsix.org/forum/viewtopic.php ... sey#239488
If one of the good large-bore Australian gaskets will do: http://slantsix.org/forum/viewtopic.php ... ket#272949
Copper works, but it's a chore to keep the engine dry. Unless you're running a very high compression ratio, a lot of boost or a lot of nitrous the copper gasket usually isn't needed.
 Post subject: Yep...
PostPosted: Mon Oct 11, 2010 9:43 pm
I second the Aussie Gasket, they have a nice fat fire ring compared to the Fel-pro gasket (and most guys run the Fel-pro gasket up to the mid-11's in SCR if not a bit more)...
PostPosted: Tue Oct 12, 2010 6:26 am
Why do you think you need copper? Maybe we can guide you to the correct gasket for your app.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Oct 12, 2010 6:29 am
Site Admin
Let's see.. You're already carrying 125 Horses in a hose... Gonna bump that up? :lol:
Contact Charlie! You might want to talk to him about using a boat load of Nitrous anyway.
CJ
PostPosted: Tue Oct 12, 2010 6:26 pm
i just figured while i have engine apart switching to 11:1 pistons i should get a good headgasket, i'm also spraying 125 shot. so i just wanted something better than stock
PostPosted: Tue Oct 12, 2010 7:19 pm
You'll need a lot more than a good head gasket to be spraying on 11-1.
Trust me on this one. 8)
PostPosted: Tue Oct 12, 2010 7:44 pm
Yikes. :shock: Good luck keeping that together. Generally speaking, a lower compression ratio and a little more N2O is faster. Same as with supercharging.
PostPosted: Sun Oct 17, 2010 7:03 am
You can spray at higher compressions, but you really, really have to watch the tune up. As fast as things can go bad in a 9-1 motor on spray, they will go bad a ton faster at higher compression.
He's going in the right direction with a copper head gasket, but really needs to have head studs too. O-ringing the decks would also be a good thing to do.
