It is currently Wed Dec 24, 2025 1:59 am
 Post subject: Brake Bleeding
PostPosted: Tue Oct 12, 2010 6:22 pm
I have a 71 Duster that has been converted to 73 front disc brakes. The master and prop valve have been converted as well. My problem is that I can't get fluid out of the rear wheel cylinders when I hook up my pressure bleeder. I can get fluid out of the lines up until the prop valve, but on the outlet line to the rear brakes, no fluid comes out. Any ideas? Thanks.
"You know a car is really yours when you've touched every fastener on it." -David Freiburger
PostPosted: Wed Oct 13, 2010 7:12 am
Plugged, connected wrong, Adjustable,
Just ideas.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Oct 13, 2010 9:31 am
Check for an internally collapsed flex hose to the axle. I recently had a brand new Wagner made-in-Italy hose fail internally. The last batch of Wagner brake hoses I bought a year ago were a mixture of made-in-USA, China, Mexico and Italy. The made-in-China hose was made a little wrong, but I made it fit, and whilethe made-in-Italy fit OK, it apparently collapsed inside trapping pressure to one wheel. The replacement hose was also made-in-Italy, but seems to be working OK.
PostPosted: Thu Oct 14, 2010 4:42 pm
So I pulled everything apart and the lines and hoses are all clear. The prop valve I just replaced with a new unit from Inline Tube. The original one was just a distribution block with a brake warning light, while the new one is correct for disc/drum applications (built in prop valve). Since everything else is clear, it leads me to believe there is a problem with the valve...
PostPosted: Thu Oct 14, 2010 5:41 pm
I'd disconnect the line starting at the wheel, have a helper push down the pedal, and start working forward. I've never seen a proportioning valve go bad, but I guess it could happen. Good luck and please let us know what it turns out to be.
PostPosted: Thu Oct 14, 2010 6:08 pm
Hi jar84203. This problem mystifies me a bit. If you have installed the necessary master cylinder/valve assy and the correct combination valve (the one distributing the lines front/rear) for use with disc brakes, there should be a hold-off valve in the combination valve, whose function is, to quote the manual, better match front disk brakes with the rear drum brakes, resulting in a improved braking and steering control on icy surfaces. Problem is, when pressure-bleeding a disk/drum brake system, there should be no problem bleeding the rear brakes, but to bleed the disks, you have to prevent the engagement of the hold-off valve. The hold-off valve is designed to delay the action of the disk brakes a little, to give the drums time to engage at a same time as the disks, and it blocks off when the pressure is between approximately 3 and 135 psi. The bleeding methods that is not influenced by the hold-off valve is pedal bleeding, gravity bleeding or vacuum bleeding. The valve is that little metal nob sticking out of a rubber grommet at the front of the combination valve that distributes the brake lines. There is a small tool available (easy made by yourself) that can be used to hold the valve in a pulled out position when pressure bleeding. I have no access to a scanner where I am right now so I cannot give you a picture, but if someone that reads this know what I talk about, has a manual and a scanner, please feel free to use them!
So, back to the mystifying bit: Is it possible that you can have switched the front/rear brake line outlets?
That would invoke the situation you describe, which is opposite of what is described above, and switching the lines again would solve your problem!
Olaf.
Aspenized
PostPosted: Wed Oct 20, 2010 8:17 pm
New master for disc/drums and new prop valve from Inline Tube. When I disassembled the new prop valve, I noticed it didn't match the picture in the FSM. Has anyone had problems with this?
