It is currently Tue Nov 17, 2026 5:05 am
PostPosted: Fri Oct 15, 2010 7:48 pm
Anyone here work on Doug Nash or Richmond 5-speeds? The keys that fit into the gears have a shoulder on them, and I'm not sure if the shoulder is supposed to face toward the tapered sliders, that are moved by the fork, or away from them.
PostPosted: Sat Oct 16, 2010 11:30 am
I'd settle for an opinionated amateur. :)
PostPosted: Sat Oct 16, 2010 5:31 pm
you mean the little bump about half way on the keys? this is on the tremec and borg warner t-5s. dont know if the doug nash or richmonds are like this but the on a tremec the "bump" faces out.
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Sat Oct 16, 2010 7:08 pm
What is labeled the "synchro assembly 1-2-3-4" has a simple key with a bump as you describe. The other keys have a T-shaped shoulder on them. I'll try to post a picture when I haven't just had multiple brewery products. :shock:
PostPosted: Sun Oct 17, 2010 11:47 am
After spending more time with the gears, I think I have it figured out. The t-shaped part of the key is toward the center of the gear, and faces away from the tapered slider, it looks like.
 Post subject: Umtr
PostPosted: Sun Oct 17, 2010 12:56 pm
Go over to UMTR's web site. I'm sure someone over there can help you out. It is the United Manual transmission Racing organization. Some day I'd like to go to one of their races. They are pretty wild from what I have seen.
Rick
PostPosted: Sun Oct 17, 2010 1:17 pm
Thanks, Rick, I'll check it out!
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Sun Oct 17, 2010 2:57 pm
I just put it together, and it all makes sense! I love it when that happens. 8)
