It is currently Tue Nov 24, 2026 3:10 am
PostPosted: Tue Nov 02, 2010 6:37 pm
when applying boost to the induction, whether via a crank driven super charger or through an exhaust driven turbo,,
1) does the intake runner length "sonic wave" phenom come into play?
2) the same question would apply on on exhaust cycle scavenging.
with a pressureized induction ,any theoretical advantage to using a hyper pac or aussie speed intake or a tuned exhaust header,, ?
thanks
PostPosted: Tue Nov 02, 2010 7:41 pm
1. Yes, but the speed of sound is higher at higher pressures.
2. How much do you want to talk about pressure wave tuning and what happens during overlap? Are you relying on a negative pressure wave from the exhaust to start the intake flow? Do you have exhaust back pressure due to a restrictive exhaust turbine?
Good manifolds are still important. The physics don't change, but the values in the equations do. Needless to say, it's complicated.
PostPosted: Tue Nov 02, 2010 7:44 pm
I think equal flow is more important in boosted applications.
