It is currently Fri Nov 20, 2026 10:38 am
PostPosted: Sat Nov 06, 2010 2:41 pm
Using a laser thermometer at the sending unit it measures about 150*, the temp gauge never climbs above the second line on the left. Is this normal or should I look into getting a hotter thermostat? I am in NY and it was probably like 55* outside today. I took the temperature after driving it for a while and then letting it idle for a few minutes.
PostPosted: Sat Nov 06, 2010 4:10 pm
A 195° thermostat is fine, but 180° is alright if it makes you fell better. Hotter is better for the engine. Too cold and the cylinders wear, the oil sludges up and fuel economy suffers.
PostPosted: Sat Nov 06, 2010 6:47 pm
What year?
Earlier models were 180, later 195.....
PostPosted: Sat Nov 06, 2010 6:56 pm
It's a 1970 duster, 225 with about 52,000 miles. I don't know what thermostat is in it now
PostPosted: Sat Nov 06, 2010 7:35 pm
put a 195 in it ...you want it here in northeast....
PostPosted: Sun Nov 07, 2010 6:48 am
Yup, a 195 is best.
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
