It is currently Fri Nov 13, 2026 4:46 pm
PostPosted: Tue Nov 16, 2010 11:02 am
Sorry for the '50s question, but it is a mopar straight 6! ;)
(c-series 3/4 ton pickup, 230cid flathead 3 on the tree)
I put a 12v generator in my old 6v truck. The last thing to get switched over is the heater box. The original one is still in there. It says mopar on it, isn't rusted out, doesn't leak antifreeze, and the electric motor worked a couple years ago when the truck was 6v. It is a really cool piece and I want to keep it.
I need to set this thing up to run the fan. It has one wire and grounds to the mount. Can I run a switch to the fan through a 1ohm ballast resistor from a dart? How well would that work? I saw voltage drops for sale on ebay for this purpose and they were listed as 1ohm, so I thought about how I already have a few 2 pole ballasts floating around as spares.
Is there a slicker and still inexpensive way to do this? If so where would I get the parts? Can I easily run a three position switch (would have to be a twist knob) or potentiometer? Maybe even a house lightswitch dressed up with an old knob? Where can I frugally source decent quality parts?
I don't have streetrod catalog money right now, and it will soon be a little cold to drive with no heat.
I've done some wiring but when it gets into ohms etc. I know just enough to be dangerous.
Thanks!
Kevin
madam im adam
PostPosted: Tue Nov 16, 2010 3:58 pm
You might be able to use ballast resistors to drop the voltage but I would think that you would have to put them in sets that are in series to get the right voltage then put a few sets in parallel to handel the current. I would get a commercial voltage drop.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Tue Nov 16, 2010 5:46 pm
Car Model: '23 T-bucket
How about checking out those resistor networks for multi-speed automotive blowers? You know.....the resistors that mount in the heating duct and use airflow to keep them cool enough to not burn out.
Seems to me that one of those should handle the current that the 6vdc fan would be pulling.
The other possibility is a salvage yard search for a 12 volt fan motor that you can adapt to the older housing.
Roger
 Post subject: Thanks
PostPosted: Wed Nov 17, 2010 5:00 am
For the good ideas.
madam im adam
PostPosted: Wed Nov 17, 2010 7:01 am
Be careful!!! Was your old wiring POSITIVE ground? Is your New wiring Positive ground. I converted an old truck to 12volt and went from positive to negative ground and you cant combine the two systems easily.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Nov 17, 2010 11:12 pm
If you have two ballast resistors you can make a voltage divider (for 6 volt they should have the same resistance).
http://www.raltron.com/cust/tools/voltage_divider.asp
 Post subject: results
PostPosted: Thu Nov 18, 2010 10:27 am
First thanks again for the help with the somewhat off topic post.
I found out the dart ignition style ballast works great...
for about ten minutes, then it overheated and failed. The fan motor obviously draws too much juice for the little element to convert 1/2 to heat and still live. Oh well. I went for the flat plastic wrench with the numbers and magnetic strip on it and bought a voltage reducer off ebay specifically for this app. Thanks again for the ideas. I guess I'm not cut out to be a shadetree electrical engineer.
PS: it is now neg. ground. I once wired a pos. ground triumph motorcycle- as simple as it is it still made my brain hurt for some reason. Stupid british lucas parts...
vroom vroom!
radar
madam im adam
PostPosted: Fri Nov 26, 2010 8:39 am
How about wiring two 6V batteries in series instead of using a 12 volt car battery? For the 6V applications you could center tap the battery rig.
Never seen a Valiant I didn't like!
 Post subject: Ah the Marine
PostPosted: Sun Jan 30, 2011 4:14 am
Affirmitory marine...
Brian Doak CMfrT
PostPosted: Sun Jan 30, 2011 5:46 am
How would you go about getting equal charge in both batteries?
How about a solid state voltage dropping device? Something like the solid state instrument regulators, but with a larger capacity.
Here is something.
http://www.speedwaymotors.com/Voltage-R ... layId=2374
PostPosted: Sun Jan 30, 2011 12:20 pm
Almost certainly easier and less expensive to replace the 6v motor with a 12v one, or have an electric motor shop rewind the existing motor for 12v service.
