It is currently Mon Nov 16, 2026 3:41 am
 Post subject: 727 adapter
PostPosted: Fri Dec 03, 2010 5:36 pm
my motor and trans i beleive is out of a late 70s ramcharger 4x4.theres a adapter between the transfer case and tranny.im just wondering if theres bearings in there? or is it just housing for the shaft?
thanks jim
dodge b150 4x4 225 supersix,8 inch lift26605_1315915292058_1055981099_30764636_7102626_n
 Post subject: -
PostPosted: Sat Dec 04, 2010 10:01 am
Yes there's a bearing,and it's important,it controls endplay in the trans. FYI,the inner shaft can't be removed w/o dissassembling the trans
PostPosted: Sat Dec 04, 2010 6:43 pm
alrite i have a grinding noise that only pops up once in a wile ,usually wen its realy pushing ,going up hills usually.if i slide the transfer case off will i be able to change the bearings?
thanks jimbo
p.s the grinding noise it was making sounded like a steel pipe being draged across concrete
