| 727 adapter https://slantsix.org/forum/viewtopic.php?t=42770 |
| Author: | 4x4jimbo [ Fri Dec 03, 2010 5:36 pm ] |
| Post subject: | 727 adapter |
my motor and trans i beleive is out of a late 70s ramcharger 4x4.theres a adapter between the transfer case and tranny.im just wondering if theres bearings in there? or is it just housing for the shaft? thanks jim |
| Author: | bigslant6fan [ Sat Dec 04, 2010 10:01 am ] |
| Post subject: | - |
Yes there's a bearing,and it's important,it controls endplay in the trans. FYI,the inner shaft can't be removed w/o dissassembling the trans |
| Author: | 4x4jimbo [ Sat Dec 04, 2010 6:43 pm ] |
alrite i have a grinding noise that only pops up once in a wile ,usually wen its realy pushing ,going up hills usually.if i slide the transfer case off will i be able to change the bearings? thanks jimbo p.s the grinding noise it was making sounded like a steel pipe being draged across concrete |
