It is currently Tue Nov 17, 2026 8:10 am
 Post subject: Handling of O2 sensor.
PostPosted: Tue Dec 14, 2010 5:13 am
When I recalibrate my sensor I wiped the carbon build up off of it. Now it is throwing error codes that Innovate says means I need a new sensor. Was touching the body of the sensor a no-no? Or was this t hing dying anyway?
The next question has to do with the brand of sensor if I replace it. Any advice there? Opinions or experience to share?
Sam
PostPosted: Tue Dec 14, 2010 3:45 pm
Try the innovate forum,
Wiping the carbon shouldn't have done anything unless you used some chemicals.
Maybe a WOT run will blast it clean.
