It is currently Sat May 30, 2026 2:07 pm
PostPosted: Mon Dec 20, 2010 2:56 pm
Hey,
I pulled out the dash of my 67 vc valiant.
now if I turn the key etc it won't start, what wires do I have to connect to what to get this to work....?
Thanks.
PostPosted: Mon Dec 20, 2010 3:09 pm
You need to re-connect the large black & red wires that went to the alturnator gauge.
PostPosted: Mon Dec 20, 2010 3:31 pm
You need to re-connect the large black & red wires that went to the alternator gauge.
Should he just bolt both wires together to each other, or put the Alt gauge between them?
PostPosted: Mon Dec 20, 2010 3:49 pm
Just bolt them together.
You may want to look for the neutral safety switch if automatic.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Mon Dec 20, 2010 3:51 pm
Bolt & nut the two eyes (black & red) together tightly, and tape the splice up using 3M’s 33 electrical tape, “the good stuffâ€￾. You don’t want that wire grounding out & melting everything back to the battery while it is flopping around with no dash to protect it, or its connection coming loose. The amp gage need not be connected.
