aluminum radiator
https://slantsix.org/forum/viewtopic.php?t=43063
Author:  dartfordoor [ Thu Dec 30, 2010 6:54 pm ]
Post subject:  aluminum radiator
I need to replace my old radiator on my 73 dart /6, was considering an aluminum radiator cheapy from Summit. I know the cheapy has no trans cooler or mounting brackets. didn't really see any mount kits, I guess people would weld an aluminum angle on the side and bolt the radiator to the support. I believe it needs to be tig welded, something I don't have. So does anyone have any suggestion, or should I get an oem made in china replacement?
Also on the radiator which is the inlet lower passenger side or upper driver side. thanks in advance... Jerry
Author:  4speed [ Thu Dec 30, 2010 7:12 pm ]
Upper is in.
Author:  Aggressive Ted [ Thu Dec 30, 2010 7:14 pm ]
I got a stock Modine with all the fittings for my 74 out of Oregon from our local Auto Parts store in here in Black Diamond.
Author:  raPoM [ Thu Dec 30, 2010 7:29 pm ]
Go to a junk yard and get a rad out of a BMW. Fits the stock rad support like it was made to go there. Just need to secure it at the top.LIGHT weight aluminum core with plastic tanks.
Author:  4speed [ Thu Dec 30, 2010 7:36 pm ]
What year/model/engine BMW?
Author:  raPoM [ Thu Dec 30, 2010 8:12 pm ]
I know nothing about BMW's other than they are all over the junkyards here. I would say it was a 7 series? With a 6??? I know the ones with 4 cyl. use smaller rads,that fit in early A's quite well.Look for one with a 6 in it and you should be set(for 67+ a body)
