It is currently Tue May 26, 2026 6:38 pm
 Post subject: aluminum radiator
PostPosted: Thu Dec 30, 2010 6:54 pm
I need to replace my old radiator on my 73 dart /6, was considering an aluminum radiator cheapy from Summit. I know the cheapy has no trans cooler or mounting brackets. didn't really see any mount kits, I guess people would weld an aluminum angle on the side and bolt the radiator to the support. I believe it needs to be tig welded, something I don't have. So does anyone have any suggestion, or should I get an oem made in china replacement?
Also on the radiator which is the inlet lower passenger side or upper driver side. thanks in advance... Jerry
PostPosted: Thu Dec 30, 2010 7:12 pm
Upper is in.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Thu Dec 30, 2010 7:14 pm
I got a stock Modine with all the fittings for my 74 out of Oregon from our local Auto Parts store in here in Black Diamond.
PostPosted: Thu Dec 30, 2010 7:29 pm
Go to a junk yard and get a rad out of a BMW. Fits the stock rad support like it was made to go there. Just need to secure it at the top.LIGHT weight aluminum core with plastic tanks.
PostPosted: Thu Dec 30, 2010 7:36 pm
What year/model/engine BMW?
PostPosted: Thu Dec 30, 2010 8:12 pm
I know nothing about BMW's other than they are all over the junkyards here. I would say it was a 7 series? With a 6??? I know the ones with 4 cyl. use smaller rads,that fit in early A's quite well.Look for one with a 6 in it and you should be set(for 67+ a body)
Users browsing this forum: Bing [Bot], Chris6064 and 5 guests
