It is currently Tue Sep 29, 2026 3:54 am
PostPosted: Tue Jan 04, 2011 7:43 pm
years ago i built my slant and had the crank checked for balance and had the machinist press the rods and pistons together and put the bottom end together. i just recently ordered some new custom pistons, and i'm wondering if i will need the rotating assembly rebalanced or checked by a machinist.
PostPosted: Tue Jan 04, 2011 7:51 pm
The crank and rods should be fine. If all the new pistons are equal in weight you're good to go.
PostPosted: Tue Jan 04, 2011 8:19 pm
I balanced all mine because it was a shop rebuild before. I'm glad I did, the crank was 16 g out and the rods were 12 g out heaviest to lightest(mismatched rods). I got the rods within 1g h to l and 2g end to end. I had my machinist recheck them too, I think he said I did better than what I thought. Rods are not hard to check weights and I made my own balancer. I had the crank balanced and polished for $50.
'72 4 dr Dart
'63 4 dr Dart
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 33 guests
