It is currently Mon Nov 30, 2026 12:49 am
 Post subject: Throttle Return Spring
PostPosted: Fri Jan 07, 2011 1:15 am
I have a 1986 Dodge D150 with the 225 six cyl engine, Holley 1945 carb with a solenoid. The throttle return spring and bracket won't fit with the solenoid installed. Previously I had a carb with no solenoid and the return spring and bracket worked fine. I can't find any pictures of the return spring and bracket used on engines with the solenoid. Any ideas?
