It is currently Mon Dec 29, 2025 9:16 am
 Post subject: Carb ID New to /6
PostPosted: Thu Jan 13, 2011 6:48 am
Hello from WA State.
My first /6 and I am restoring a 83 SWB miser pickup. Can I get some Help identifing this carb.
Holley
40093
4287053
0444
Thanks.
88 W250 360
83 D150 Miser
PostPosted: Thu Jan 13, 2011 7:54 am
Hi kennewick, and welcome to the forum!
The carburetor may be a 2-bbl Holley 2280. You should go to the engine section, Frequently Asked Questions, and follow the links (all red text are links) in 'Carburetor operation & repair information'. There you will some material on the Holley 2280, so you can confirm that it is the same as your carb. For specific info, you should use the search function to look up posts dealing with your carb - there are lots of them, so you should be able to find answers to many questions there.
If you have questions not answered there, post some pics if possible, and give as much info as possible when posting a question.
Olaf.
Aspenized
PostPosted: Thu Jan 13, 2011 8:55 am
Thanks Olaf, I am getting used to where everything is here. I did find some info and it is a 2280 Holley. :D
88 W250 360
83 D150 Miser
