It is currently Mon Nov 09, 2026 9:05 am
PostPosted: Sat Jan 22, 2011 12:27 pm
On doing a band adjustment, one step in my factory manual reads: "Using wrench, Tool C-3380 with adapter C-3705, tighten band adjusting screw..."
I gather tool C-3380 is simply an inch-pounds torque wrench - will any old one do? And is adapter C-3705 necessary? The manual implies it's not.
Just trying to get all my ducks in a row before I start taking things apart. Thanks very much.
J.R.
Tucson, AZ
'68 Dart 270 with a '76-'80 engine
PostPosted: Sat Jan 22, 2011 2:44 pm
6 Pack Dart
I use any wrench to hold the adjuster while locking down the nut. Yes use any inch/pound torque wrench to adjust.
Richard
PostPosted: Sat Jan 22, 2011 3:06 pm
The last time I adjusted the bands in the 904 in my brother's van, I followed slantzilla's advice and screwed the adjuster down finger tight then backed it off 1.5 turns. So far, so good.
PostPosted: Sat Jan 22, 2011 7:47 pm
For the adapter you can use either an 8 or 12 point socket that fits.
 Post subject: ,
PostPosted: Mon Jan 24, 2011 4:26 pm
Tool c-3705 isn't needed,but an inch-pound torque wrench is a must.Check the 7 digit part# to find out what year the trans is,and find adjustment info for the exact year.The adjustment specs changed several times,might not be the same for S/6s and V-8s and your trans might not be the original one.Tool 3705 alters the torque reading of the torque wrench,so use the "true torque" specs.You will also need a 5/16 4 or 8 point socket,or a metric 12 point may work
PostPosted: Tue Jan 25, 2011 9:44 am
Awesome. Thanks so much, guys. I will employ all of your advice. I got the torque wrench and I'll attack it this weekend.
J.R.
Tucson, AZ
PostPosted: Wed Jan 26, 2011 10:01 am
Note that the bands don't take all that much torque, so get a little 1/4" drive torque wrench; I've an inexpensive click model that I've used for years taht seems fine.
Users browsing this forum: Ahrefs [Bot] and 6 guests
