It is currently Fri Nov 20, 2026 8:47 am
 Post subject: Hot Rod Aluminum Block
PostPosted: Sun Jan 23, 2011 12:34 am
So I have what seems to be a good core Aluminum block with head I pulled awhile back from a pick and pull.
I see no significant corrosion at the deck or in water jackets.
It also had a a good gasket seal. Slight ridge at the top of the cylinders.
I understand that I'd be limited as far a build up so my plan would be to do an overhaul or minor warm over.
i'd then polish it up, add muticarbs, headers etc and do a Mopar roadster to show off the motor.
no need for lots of power in a light weight rod.
Question:
What would be a good formula for this?
and the $64,000 question: Where do I find a head gasket or am I screwed?
Thanks,
Al
 Post subject: starting point
PostPosted: Sun Jan 23, 2011 8:17 am
Here's something on the subject: Twiggy and also Buster
PostPosted: Sun Jan 23, 2011 9:33 am
Head gasket just sold last week on ebayg for~$74.
PostPosted: Sun Jan 23, 2011 3:23 pm
Thanks for leads on some great info!
So if I understand correctly,
if I do a block fill operation to close the
deck I can run a standard iron block gasket ?
PostPosted: Mon Jan 24, 2011 8:50 am
No... the edge along the lifter gallery is different and the iron block's head gasket does not cover that edge...
Users browsing this forum: Bing [Bot] and 8 guests
