Brake Caliper Anti-rattle spring O ring
https://slantsix.org/forum/viewtopic.php?t=43365
Author:  jkotis [ Mon Jan 24, 2011 11:39 am ]
Post subject:  Brake Caliper Anti-rattle spring O ring
How do you position the O ring under the brake caliper anti-rattle spring on a 1986 Dodge D150 pickup? The Service Manual is not clear on the position of the O ring (looks like a black rubber band) under the anti-rattle spring. Does it just go around the bolt and lay against the inner rectangular part of the retainer clip?
Author:  Joshie225 [ Mon Jan 24, 2011 12:13 pm ]
The band is supposed to go around the caliper mount before the caliper is installed so the band lays in the square corner, but I feel they are of so little value I don't bother. Mine go into the garbage.
