optimal jet size (van)
https://slantsix.org/forum/viewtopic.php?t=43396
Page 1 of 1
Author:  Ed Mullen [ Thu Jan 27, 2011 10:46 am ]
Post subject:  optimal jet size (van)
I'm going to send my Holley 1945 out to a local carb shop for rebuild.
Without direction from me to the contrary, they are going to jet it per original specs.
Inasmuch as it is a lean-burn, I'm guessing that the original main jet is undersized, and the power valve oversized.
Since it's a van, my only goals are torque and fuel economy.
What direction should I give the shop re. jetting?
(lean burn is intact, btw, but is getting swapped for HEI in a few years when it is eligible for Q plates. I'm keeping the 1945 until the next time it needs a rebuild--it has the appropriate port for a vac-advance distributor-- then hopefully, switching to a 1920.)
