It is currently Thu Nov 19, 2026 9:41 pm
 Post subject: optimal jet size (van)
PostPosted: Thu Jan 27, 2011 10:46 am
Car Model: 87 B150, 1970 Valiant 4-door
I'm going to send my Holley 1945 out to a local carb shop for rebuild.
Without direction from me to the contrary, they are going to jet it per original specs.
Inasmuch as it is a lean-burn, I'm guessing that the original main jet is undersized, and the power valve oversized.
Since it's a van, my only goals are torque and fuel economy.
What direction should I give the shop re. jetting?
(lean burn is intact, btw, but is getting swapped for HEI in a few years when it is eligible for Q plates. I'm keeping the 1945 until the next time it needs a rebuild--it has the appropriate port for a vac-advance distributor-- then hopefully, switching to a 1920.)
