It is currently Mon Nov 09, 2026 1:48 pm
PostPosted: Mon Jan 31, 2011 12:42 pm
After looking on our site here ...I found a link provide by one of our members... [url]http://www.technicalvideos.com/what_year_727.phtml
On this site I was reviewing and trying to identifying the type of 904 (spare ) transmission I had picked up awhile ago when I picked up a /6 motor from a 68 Dart..
Since I am new to this...My question is this... Did the 904 and 727 share similar splines? Regarding lockup or non-lockup? If you see the info below which is linking pictures from website provided above
The 904 (non-lockup style) was built from 1960-1977. Notice how the splines go to the end of the shaft (see Fig. 1 on left). The 904, nonlock-up style, is preferred for performance building.
The 904 (lockup style
) was built from 1978-1993. This style uses a torque converter with an internal clutch. Notice the machined area where the clutch inside the converter will seal (see Fig. 2 on left).
The 727 (non-lockup style) was built from 1962 and on. Notice how the splines go to the end of the shaft (see Fig. 1 on left). The 727, non-lockup style, is preferred for performance building.
The A727 (lockup style) was built from 1978-1993. The A727 uses a torque converter with an internal clutch. Notice the machined area where the clutch inside the converter will seal (see Fig. 2 on left).
BIG T
1967 Dart "Six Shooter"
Girlfriend Rhonda... 66 Valiant
Image[/URL]
 Post subject: ,
PostPosted: Mon Jan 31, 2011 2:41 pm
There are 3 diferent input splines for the 904. 67 and older course spline,68-up fine spline,and then lock-up.Many tranmission books don't disscuss the course spline because it is so old,and not used for racing because of poor torque converter availibility
PostPosted: Mon Jan 31, 2011 2:47 pm
727 has a larger input and output shaft.
PostPosted: Mon Jan 31, 2011 4:53 pm
Output IIRC same as the 4 speed?
PostPosted: Mon Jan 31, 2011 5:10 pm
727s and most 4-speeds have the larger output shaft, but the '66-'67 A-body A833s and some A833ODs have the smaller output shaft.
Here is info on automatic transmission input splines: http://www.moparts.org/Tech/Archive/auto/7.html
