It is currently Fri Jul 17, 2026 10:45 pm
 Post subject: What is needed?
PostPosted: Sat Jan 29, 2011 11:59 am
Do you have to have a set of fenders and a hood on a car to run at the drag strip? Do you need any lights? front or rear? Just thinking ahead for Mason Dixon.
Rick
PostPosted: Sat Jan 29, 2011 1:57 pm
I have seen guys make passes with cars with the front end off, but you may want to check with the track.
There used to be a rule that you had to have a hood on a car with the engine driven fan.
Rulebook says you have to have at least one red light on the rear. Headlights are optional. :D
 Post subject: Thanks Slantzilla
PostPosted: Sat Jan 29, 2011 2:53 pm
I will be using an electric fan so I may be Ok. I will check with the track and see what they say.
Rick
PostPosted: Sun Jan 30, 2011 5:00 am
I would say it has alot to do with the track. I think the rules say the car must look presentable.
Will
PostPosted: Sun Jan 30, 2011 6:41 am
Will
That is a NHRA rule that is basically enforced at "Major" meets. Most tracks, on the weekly races could care less what the car looks like. Just have the entry fee. I run my 66 Valiant without a hood, and have not been questioned. I do have an electric fan, however.
PostPosted: Sun Jan 30, 2011 7:00 am
Yes, alot of times it is up to the track tech department, and sometimes they are not that savvy on the rulebook anyway. (i.e. seat belts in a slow car with a bar)
Some of the tracks I have run at allowed things that were in no way safe. :shock:
PostPosted: Sun Jan 30, 2011 9:40 am
Apparently, not much! :lol:
PostPosted: Sun Jan 30, 2011 10:17 am
Well they require at least half a fender, have you ever seen my truck :lol: :lol:
Nick
86 d150 turbo /6.
PostPosted: Mon Jan 31, 2011 6:14 am
I saw a guy running a 350 transplanted into a Duster, and they removed the firewall. Worst I've seen. This was at Wilkesboro 5 yrs ago. The guy could have reached over and run the throttle blades with his hand.
Also saw a guy running a 34 coupe at Carlsabad, CA around 140 MPH trap speed, and his seat looked like an aluminum lawn chair...
PostPosted: Mon Jan 31, 2011 4:27 pm
Yes But I believ Wikesboro and Knoxville dont have Tech - At least not when I was there - :-0
Better bring your helmet Rick!
