It is currently Fri Nov 13, 2026 9:02 pm
PostPosted: Sun Feb 13, 2011 4:44 pm
i am about ready to install the slant in the 40 plymee, and in assembling the drive line, i ran accross a problem!! it is a 66 engine with a small crank register for the flywheel. my flywheel is from a later engine. ie: register hole too large.
do i have to changeout the crankshaft with a later one? which i do have here, get a new flywheel with the smaller register, or can i use it the way it is. i concerned that it may shake a little or come loose .
Chuck
PostPosted: Sun Feb 13, 2011 4:47 pm
or could i have a machine shop make a reducer ring to fit both?
PostPosted: Sun Feb 13, 2011 5:50 pm
you can get one made ....someone here on board might also have some
keep on roddin'
PostPosted: Mon Feb 14, 2011 9:27 am
Or find a small pilot flywheel...
PostPosted: Mon Feb 14, 2011 11:30 am
i think i located a fly wheel through the link on the forum under "wanted"
thanks for the responses.
