It is currently Sun Nov 15, 2026 3:20 am
PostPosted: Wed Feb 23, 2011 3:33 pm
I've read I can install a dual field alternator where a single field one was by simply grounding one of the field wires.
Does it matter which field wire I ground?
Thanks guys! :D
Scott - waywardgarage.com
Why is the rum always gone? Image
PostPosted: Wed Feb 23, 2011 3:42 pm
Yes, and no it doesn't matter which side is grounded.
PostPosted: Wed Feb 23, 2011 3:54 pm
Thanks Josh! :D
PostPosted: Thu Feb 24, 2011 12:25 pm
I grounded one of my field terminals to the alternator body,is this where it should be grounded?
DRIVE IT,DON'T HIDE IT
PostPosted: Thu Feb 24, 2011 2:30 pm
I grounded mine to the block, it is a good ground connected to battery. I don’t trust the electrical competence of the bracket holding the alternator.
PostPosted: Thu Feb 24, 2011 4:50 pm
^ Now that's a better idea,cheers.
PostPosted: Thu Feb 24, 2011 4:57 pm
You better, as that is the ground path for the alternator power.
PostPosted: Fri Feb 25, 2011 6:17 am
Good point...
