It is currently Sun Nov 15, 2026 11:10 pm
 Post subject: Valves & rings ?
PostPosted: Wed Mar 09, 2011 7:09 pm
Got a 72 B-300/6
Engine runs rough with no power.
Got approximately 1 115-120
2 115-120
3 85 -85
4 115-120
5 105-115
6 115-120
after 3 or 4 revolutions with throttle and choke open.
engine burns no oil and does not smoke. I have a point system and am checking it out now. Carburetor is a one bbl 1920 (i think)
QUESTION with these comp numbers, should i be looking at a rebuild or just a good vlv job. Engine was rebuilt several yrs ago but details and components unknown. Have had to replace a couple of valves in the past as they were deformed and burnt.
thanks in advance
FRCC
(9) slant six engines / + misc parts for same.
1969 D100 318 4 spd
PostPosted: Wed Mar 09, 2011 7:24 pm
Site Admin
Check valve lash on cylinder #3 first. If that's good, it looks like a valve on #3 is your problem.
Your numbers are dry-wet, correct?
CJ
 Post subject: rebuild or valves
PostPosted: Wed Mar 09, 2011 7:26 pm
thanks cj
yep, checked lash today and found no tight valves. Adjusted all intake and exh
what do you pros use to determine if rings need replacing?
I have placed oil in the cylinders and the effect was small during comp testing
FRCC
1969 D100 318 4 spd
PostPosted: Wed Mar 09, 2011 7:33 pm
no didn't check wet today the variations was just when i check them more than once.
Will check dry and wet tomorrow and post. How much diff would indicate rings? Or, how much diff should there be?
FRCC
1969 D100 318 4 spd
 Post subject: Some difference...
PostPosted: Wed Mar 09, 2011 8:04 pm
The compression check number would be a night and day difference (I've seen a 10psi cylinder go to 45 on the wet check...LOL)...
The next step would be a leakdown test that would determine if it was cylinder/valves/gasket (all of the above).
 Post subject: valves and rings?
PostPosted: Wed Mar 09, 2011 8:21 pm
forgot to mention oil pressure is 50-60 lbs at warm idle.
will also do leak down tomorrow as well as wet comp, that should tell me whats wrong i guess.
FRCC
1969 D100 318 4 spd
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 2 guests
