It is currently Wed Oct 14, 2026 1:16 am
 Post subject: Oil filter analysis
PostPosted: Thu Mar 24, 2011 4:51 pm
I'm a frequent lurker on BITOG but thought this question would best be answered here. What is made of copper in a slant six? I just cut open my oil filter and between the pleats were little flakes of copper. There were little chinks of "black sand" that I assume is just carbon crud. But there was a whole lot of copper.
I don't want to spend a lot of $$$ on oil analysis for this engine, as its past is somewhat sketchy. Basically, it's a forklift motor that saw infrequent oil changes, ran for a few minutes at a time and then got shut off, and generally was abused. When I changed the head gasket 3 months ago the cylinders looked pretty good considering. I vatted the head to get rid of copious amounts of carbon while I was in there.
So, could this be bearing material? There's no knocking of any kind on this engine.
PostPosted: Thu Mar 24, 2011 5:51 pm
Tri-metal bearings are about the only source of copper flakes I can think of.
PostPosted: Thu Mar 24, 2011 6:17 pm
Maybe a non plastic distributor gear.
Sure it's copper?
The metal in engines tends to get stained a copperish color from oil...........
PostPosted: Thu Mar 24, 2011 6:35 pm
Sure it's copper?
Hmmmm... it isn't magnetic, but you may be onto something. :shrug:
I am guessing from the lack of maintenance it may very well not be copper. The oil pressure is very good and the rods or mains are not even lightly tapping (using a stethoscope). All I can hear is rocker arm chatter.
I am gonna toss in a quart of Marvel Mystery Oil and change the oil again in about 40 hours to see what comes out. I sure hope it isn't bearings because this thing is a real PITA to work on!
Users browsing this forum: No registered users and 160 guests
