| Oil filter analysis https://slantsix.org/forum/viewtopic.php?t=44183 |
| Author: | coconuteater64 [ Thu Mar 24, 2011 4:51 pm ] |
| Post subject: | Oil filter analysis |
I'm a frequent lurker on BITOG but thought this question would best be answered here. What is made of copper in a slant six? I just cut open my oil filter and between the pleats were little flakes of copper. There were little chinks of "black sand" that I assume is just carbon crud. But there was a whole lot of copper. I don't want to spend a lot of $$$ on oil analysis for this engine, as its past is somewhat sketchy. Basically, it's a forklift motor that saw infrequent oil changes, ran for a few minutes at a time and then got shut off, and generally was abused. When I changed the head gasket 3 months ago the cylinders looked pretty good considering. I vatted the head to get rid of copious amounts of carbon while I was in there. So, could this be bearing material? There's no knocking of any kind on this engine. |
| Author: | Joshie225 [ Thu Mar 24, 2011 5:51 pm ] |
Tri-metal bearings are about the only source of copper flakes I can think of. |
| Author: | emsvitil [ Thu Mar 24, 2011 6:17 pm ] |
Maybe a non plastic distributor gear. Sure it's copper? The metal in engines tends to get stained a copperish color from oil........... |
| Author: | coconuteater64 [ Thu Mar 24, 2011 6:35 pm ] |
Quote: Maybe a non plastic distributor gear.
Hmmmm... it isn't magnetic, but you may be onto something. :shrug: Sure it's copper? The metal in engines tends to get stained a copperish color from oil........... I am guessing from the lack of maintenance it may very well not be copper. The oil pressure is very good and the rods or mains are not even lightly tapping (using a stethoscope). All I can hear is rocker arm chatter. I am gonna toss in a quart of Marvel Mystery Oil and change the oil again in about 40 hours to see what comes out. I sure hope it isn't bearings because this thing is a real PITA to work on! |
