| Brake and axle bolt pattern questions and options. https://slantsix.org/forum/viewtopic.php?t=44350 |
| Author: | drgonzo [ Mon Apr 04, 2011 12:44 pm ] |
| Post subject: | Brake and axle bolt pattern questions and options. |
Guys have an 8.75 under a 71 valiant I want to use in my 63 dart and the front disc brakes. Has anyone re-drilled the 8.75 axle flanges for the BBP? Up front can I swap on BBP hubs and caliper brackets or what? |
| Author: | Joshie225 [ Mon Apr 04, 2011 12:56 pm ] |
Yes, you can have your rear drums and axles redrilled. Generally screw in studs are used as they don't need as large a hole in the axle. Which disc brakes? Assuming you have small bolt pattern K-H disc brakes you're stuck using the original calipers, but I would check with Stainless Steel Brakes to see if their dual-bolt-pattern discs will work on the original spindles. Most people wanting big bolt pattern discs use the '73+ stuff. |
