It is currently Sun Nov 22, 2026 6:40 am
PostPosted: Fri Apr 08, 2011 10:10 am
Anyone ever use a truck linkage rod on a pass car? I know the throttle cable bracket is the same, but it looks like the linkage rod is slightly different between a car and a truck. Seems the truck rod has a semi circle bend in it whereas the car rod has a 90' bend.
PostPosted: Mon Apr 11, 2011 5:15 am
Hmmm..no one has seen this before? [/img]
PostPosted: Thu Apr 14, 2011 9:20 pm
I'm fairly sure my supersix kickdown linkage originated from a pickup, and is now attached to a 72 Dart. Doesn't seem to be any issues, but maybe take a picture of each to show us what you're referring to?
PostPosted: Thu Apr 14, 2011 10:12 pm
I can verify that the long kickdown rod on a van is different than on a passenger car due to the shifter linkage arrangement on a van. The two are not interchangeable when used on a van. I can't verify a truck two barrel kickdown is different, but I would not be surprised if it was.
PostPosted: Fri Apr 15, 2011 3:37 pm
Ruh Roh! Watch my tranny grenade in a few hundred miles :shock:
