It is currently Sun Nov 22, 2026 2:00 pm
 Post subject: 727 noises...
PostPosted: Sat Apr 23, 2011 11:40 am
i lost the rear in my a100 some months ago... i dropped the drive shaft but haven't gotten around to fixing the rear yet... i went to start it today and of course the trusty slant fired right up, so at idle (which may be a tad high) i decided to shift into reverse and drive and back into park... i expected the noise when putting it into park but it clinked and clanked some in reverse and drive... is this normal?
PostPosted: Sat Apr 23, 2011 3:34 pm
Broken driveshaft can damage the rear sprag in a Torquflite. Time to pull the trans apart and check.
Driving it with a damaged sprag can lead to really bad things happening. :shock:
PostPosted: Sat Apr 23, 2011 5:32 pm
just to clarify, i didn't break the drive shaft... the rear end burned up on the highway and i stopped driving it... i was running it with the drive shaft completely disconnected... in the driveway...
PostPosted: Sat Apr 23, 2011 5:53 pm
never mind... it was the front yoke spinning and clanking... i forgot to take it off... thanks...
PostPosted: Sun Apr 24, 2011 5:15 am
:D :D :D :D
