| 727 noises... https://slantsix.org/forum/viewtopic.php?t=44682 |
| Author: | mrfoochie [ Sat Apr 23, 2011 11:40 am ] |
| Post subject: | 727 noises... |
i lost the rear in my a100 some months ago... i dropped the drive shaft but haven't gotten around to fixing the rear yet... i went to start it today and of course the trusty slant fired right up, so at idle (which may be a tad high) i decided to shift into reverse and drive and back into park... i expected the noise when putting it into park but it clinked and clanked some in reverse and drive... is this normal? |
| Author: | slantzilla [ Sat Apr 23, 2011 3:34 pm ] |
Broken driveshaft can damage the rear sprag in a Torquflite. Time to pull the trans apart and check. Driving it with a damaged sprag can lead to really bad things happening. |
| Author: | mrfoochie [ Sat Apr 23, 2011 5:32 pm ] |
just to clarify, i didn't break the drive shaft... the rear end burned up on the highway and i stopped driving it... i was running it with the drive shaft completely disconnected... in the driveway... |
| Author: | mrfoochie [ Sat Apr 23, 2011 5:53 pm ] |
never mind... it was the front yoke spinning and clanking... i forgot to take it off... thanks... |
| Author: | slantzilla [ Sun Apr 24, 2011 5:15 am ] |
