It is currently Thu Jun 18, 2026 6:26 pm
PostPosted: Mon Apr 25, 2011 11:50 am
While servicing the valve train, and replacing one of the rockers, I noticed that one of them had a slight bend it. The bend starts at the rocker shaft, and extends to the valve end of the rocker. The distance off of center line is about 3/32â€￾ – 5/64â€￾. Wear pattern from valve stem looks to be centered on rocker’s pad.
Should this be something I should replace, or let it be. I suspect that this is a relic of one of five past blown engines from the car’s drag racing days.
Bill
PostPosted: Mon Apr 25, 2011 2:32 pm
If it's working and has a good wear pattern... I would leave it alone.
PostPosted: Mon Apr 25, 2011 3:03 pm
Thanks Doc.
Users browsing this forum: Amazon [Bot], Google [Bot] and 7 guests
