| Rocker with a whoop in it Q https://slantsix.org/forum/viewtopic.php?t=44718 |
| Author: | wjajr [ Mon Apr 25, 2011 11:50 am ] |
| Post subject: | Rocker with a whoop in it Q |
While servicing the valve train, and replacing one of the rockers, I noticed that one of them had a slight bend it. The bend starts at the rocker shaft, and extends to the valve end of the rocker. The distance off of center line is about 3/32†– 5/64â€. Wear pattern from valve stem looks to be centered on rocker’s pad. Should this be something I should replace, or let it be. I suspect that this is a relic of one of five past blown engines from the car’s drag racing days. Bill |
| Author: | Doc [ Mon Apr 25, 2011 2:32 pm ] |
If it's working and has a good wear pattern... I would leave it alone. DD |
| Author: | wjajr [ Mon Apr 25, 2011 3:03 pm ] |
Thanks Doc. |
