It is currently Thu Oct 22, 2026 8:53 am
 Post subject: Vacumn Amplifier Test
PostPosted: Sun Nov 17, 2002 10:01 am
82' D 150 Lean Burn. My vac amp is not providing vac to my EGR valve. Is there a simple way to test the vac amp? I don't have a vac gage. An explanation of how this vac amp sys works would help. Thanks
PostPosted: Sun Nov 17, 2002 10:54 am
I don't know the answer to your question ; however , I know that for years people have been swapping out the "lean burn" for a standard electronic ignition system. I work as a tech at a chrysler dealership , and was told by the old veterine's that it was a very common swap that was performed back in the day as the lean burn system is "junk". That being said , I've also heard alot of people on boards such as this say "the first thing I would do is get rid of that lean burn" :) so that's my advice. you can still get a complete kit to perform the swap right from chysler , or go with some of the aftermarket systems like pertronix that alot of people use , or go the junk yard route.
 Post subject: Thanks...but
PostPosted: Mon Nov 18, 2002 8:49 am
Squeek, thanks for the reply. Unfortunately I live in CA. where swapping out the lean burn cannot be done. Vehicle must retain all original smog equipment even if altering it would improve emissions.
Users browsing this forum: Ahrefs [Bot] and 19 guests
